Which one is faster Oday Widgeon or a Sunfish?
Aug 25, 2019
4
Oday Widgeon US
Hi guys,
I am trying to take a decision of which one "keep/go for it" considering my actual interests of cruising and as a newbie I have maybe a "dumb" question. For what I see the Sunfish is more like a "Racing" boat but the Oday Widgeon is more like a cruising with guest boat BUT if I put the same wind and exactly same skilled sailor in both which one will perform faster and why?
my curiosity comes because ok the Sunfish looks like a more "Racing" profile but hey, I have a jig in the Widgeon, should not be faster because of that? I mean, is more sail that is going to grab the wind, while the Sunfish only has the main.
I appreciate any info with facts, I know, like everything else, there has to be tons of Sunfish lovers and haters as the same as tons of Oday Widgeon lovers and haters, I get it, I just want to learn the fact of the jig and if it makes a boat faster than others without jig.
Thanks in advance.
Jun 4, 2004
89
- -First 310 -
Sailboat speed is a function of many factors. Weight, hull form, sail area, ballast, and point of sail.
The Widgeon is about 60 lbs heavier than a Sunfish and the hull does not appear to one that can easily get up on plane.
The Widgeon will be a drier boat than the Sunfish and for the less agile a more comfortable ride.
Likes: Colo-pr
Aug 25, 2019
4
Oday Widgeon US
Sunfish has a portsmouth rating of 99, Widgeon is 122 so the sunfish will be faster. With a little research you can figure out what those numbers mean and how much faster the sunfish will be. I personally won't worry about which might be faster, I'd get on the water and go sailing.
And its a "jib" and a "jig".
perfect, thanks, also thanks for the correction about jib
Jun 2, 2004
3,607
The Widgeon is a much more comfortable boat and much easier for two people to enjoy. I am guessing from your interest in speed you are on the younger and more agile side of life so comfort might be less of a factor for you. I learned to sail on Widgeons and have two Sunfish in my backyard right now. I'd love to have a Widgeon to goof around on.
One other factor there is much more room for a cooler to keep your beer cold on a Widgeon so there is that too.
dLj
Mar 23, 2017
4,768
I've never sailed a Widgeon. I've sailed lots of Sunfish. Sunfish are a lot of fun. That being said, the Widgeon looks like a really nice little boat to sail. I love the additional sails, you can throw up a spi on one even! You throw into the mix your "actual interests in cruising" but you haven't defined that. If what you are looking for is a boat that is a lot of fun, pretty fast, and can be used to teach you the beginnings of how to handle large cruising boats, then I'd go with the Widgeon - it has more sails to play with. Looks like both would be a real blast sailing! I know first hand the Sunfish is great to sail on.
A number of years ago, I'd come back to the states to visit some friends and we were out on Long Island. One of my friends knew I had a sizeable blue water boat and had been sailing for a number of years on the ocean. We were hanging out on a beach and they had a Sunfish. We went sailing on the Sunfish and my friend asked if this must be boring for me now. I told her no way! I love sailing, and Sunfish are a real bast to sail! I would have said the same on a Widgeon, I'm sure...
Both would be great fun. You can't really go wrong.
dj
Aug 25, 2019
4
Oday Widgeon US
I am looking more like a "cruising" and have fun with my daughter. I dont think I am too agile being in my 40s but looks fun when I see Sunfish videos. The reason I have asked is because I only had a chance to use my Widgeon once and the wind that day was soooooo low that I even needed the electric trolling motor to move in and out of the dock. Then I see the sunfish videos where people even use the sail to get out of the docks really quick that makes me wonder if they are faster.
I know, I need more practice and maybe next time I have better luck with the wind and sail the Widgeon in a decent speed for a newbie, I just found a very good local deal for a Sunfish (1k) that makes me wonder if I am going to need it and should pull the trigger...did I mentioned that I am a compulsive buyer? LOL
Aug 25, 2019
4
Oday Widgeon US
that is a BIIIIIIIIG plus, nothing else to say, Ill keep the Widgeon for now.
Jun 1, 2004
8,260
Well, if you're looking for speed and excitement.... go for a beach cat(catamaran).. Hobie 16's are the most common.
if you want to stay mono hull.... rather than a sunfish, go for a Laser....
