So... about a week ago after a lovely late afternoon sail on our ‘86 C22, we were coming back into the harbor at our sailing club. I was about 10’ from the wall I typically tie up to before putting it back on the trailer for the evening (we keep the boat mast up on the trailer when not in use). As usual I was motoring in slowly while my wife was raising the keel, which we need to do since that part of the harbor is only a little more than 4’ deep. All of sudden instead of the nice steady click click you usually hear from the winch as the keel is raisesd, we heard a loud whirr/rumble of clicks... and then a thud from the keel. The next thing we know, the boat came to a sudden halt right in the middle of the harbor. My initial thought was that the keel cable broke off or somehow came loose... it took me a while to realize that it was the winch itself. Sure enough after getting a look at the keel winch by poking my head in by the port settee, I saw the following:
The ratchet drive shaft was shifted to the right, with threads showing on the left side by the ratchet gear. And when I turned the handle I saw the ratchet gear slipping. My immediate thought was that the shaft was unscrewing from the handle... so I grabbed an adjustable wrench and tightened the bolt on the winch handle... it wasn’t super-loose and I’m pretty sure I only tightened it up about a half a turn... but when I turned the handle again, the ratchet held... and, praise the lord, I was able to bring the keel up all the way. Not wanting to press my luck... we quickly got out of dodge... i.e., got the boat tied up and back on the trailer.
Later, I found this image from the tech manual that suggests that the circle clip on the drive shaft (which is on the left side in this picture) let go.
After I got home and looked the first picture over, I decided to bite the bullet and order a new winch from CD. And since I saw a couple of loose strands on the cable spool, and haven’t inspected the keel lifting components before, I also ordered CD’s keel lifting hardware kit, which includes a new cable, turning ball, hose and clamps, clevis pin, etc. Although it totaled a solid “boat buck” plus... it’ll allow me to get back on the water right away. And if it’s doable, I’ll see about fixing/rebuilding the old winch and selling it or passing it on.
I’ll return to outline what I learned during the repair. But for now, I didn’t see any prior posts on keel winches failing... I was wondering if anyone had experience with that happening or know what’s involved in rebuilding the winch itself? Tips on rebuilding a wench would also be welcome.
