New windows.
Aug 26, 2019
69
Hunter 260 Eau Claire
A Hunter 260 I’m thinking about buying needs the front windows replaced. Is that difficult and can you even get them? It is a 1996 260
Phil Herring
Alien
Mar 25, 1997
4,924
- - Bainbridge Island
I believe we have those -- click the Parts -> Hunter link in the left-side menu and use the dropdown menu to select the 260. They should be there.
Feb 18, 2011
341
Hunter 260 Cave Run Lake, KY
As far as instructions for replacement, Hunter has several files on their web site- look in this folder, there are 2-3 files that will help.
And if you click "parent directory" at the top, you will find a whole library of files related to the older Hunter boats, lots of good stuff there.
Finally, check your model number- the 260 was not made in 1996. That would have been the 26, and the front windows are very different. The 26 has a opening hatch as the center piece of the front window, the 260 does not.
:plus:
