Vent line maintenance
RNC725
51
Hunter 326 Lake Thurmond, GA
How often does everyone check their vent lines and /or make sure they're not clogged? I'm talking holding tank and water tank although I suppose I should include fuel as well.
Shooting a water hose from the outside of the holding tank makes sense--not so much on water and fuel. Nothing seems to be stopped up just trying to be proactive.
Dec 2, 1997
9,011
- - LIttle Rock
A fuel or water tank vent line clog is very unlikely...I've never heard of any that weren't the result of a kinked vent line. The holding tank vent is another story...insects are attracted to 'em, the fuel vent thru-hulls that builders use on all vents either have screens in 'em that get clogged by corrosion or dust or pollen, or tiny slits in the bottom that even salt from sea water splashes can block...a design that makes it impossible to backflush the line. Add waste spilling into the vent line if the tank is over-filled, or even due to heeling to all that and you have a tank vent that's guaranteed to become blocked, either at the thru-hull or the other end of it--that end of the hose and/or the vent fitting on the tank.
The easiest way to prevent a blocked holding tank vent: replace the "vent" thru-hull with an open bulkhead or "mushroom" thru-hull that you can put a hose nozzle against to backflush the line every time you wash the boat and/or pump out.
Spring is when mud daubers build their nests, and they LOVE holding tank vents! So one of the first things you should do every time you use the boat each spring is check the vent thru-hull for a mud dauber nest, even if you didn't find one last weekend 'cuz the li'l buggers can pack a vent line in a just a couple of days. You may have to use a screwdriver blade or ice pick to break up the nest before you can flush out the line.
Every boat owner is full of good intentions to check the vent and backflush it regularly, but nobody's perfect. So pay attention to how your toilet is behaving. If a manual toilet is getting harder to pump, or any toilet starts bubbling or "burping" when you flush, that's a good indication of a blocked tank vent...it means the tank is becoming pressurized, creating back pressure that prevents bowl contents from going anywhere. If you hear hissing in the toilet during pumpout, that's a definite indication that the vent is blocked 'cuz if the pumpout can't pull in any air through the vent to replace contents as they're pulled out, it's gonna try to pull in air from anywhere it can. Stop pumpout immediately and clear the vent line!
Hope this answers your question!
--Peggie
Jan 5, 2018
187
Hunter H34 0828 New Orleans
Very timely. Unclogged my vent line today after I noticed a lot of back pressure during a flush. Vent Line was 100% clogged. Took a few squirts with City Water Hose to break through. Then went ahead and ran 3-4 gallons through.
Jul 7, 2004
8,536
Hunter 30T Cheney, KS
My fresh water tank vent never plugs but I added a ShurFlo inline filter to keep bugs from getting into the tank.
My fuel tank had an H2Out filter to absorb moisture before it reaches the tank.
I replaced the hooded vent cover on the holding tank with a mushroom for easy cleaning.
Dec 25, 2000
6,052
In our case the PO was a possible culprit by over filling the holding tank causing waste particles to back up into the vent line and against the scupper screen before drying. Could have been a critter nest, but as I recall the plug seemed to be on the inside of the screen.
That was in 2002 and by using the pump out practice that is covered in my article after each cruise, the system has been trouble free ever since; well except for a clogged sanitation hose: https://hunter.sailboatowners.com/mods.php?task=article&mid=45&aid=100188&mn=42
Oct 27, 2016
0
Seattle
And now a word from the sponsor...
Hunter replacement stanchions
From current Marlow-Hunter boats to the classic cherubinis of the 80s, we have most stanchions and bases available, many of them in stock for quick shipment.
See the product
