Hi folks, there was a recent discussion about batteries and refrigerators and how to prevent the fridge from damaging the batteries in the event the marina's power went out for an extended period of time. I can't remember if it was on this site, or another site, but it got me thinking...
A few years ago I installed a Dometic(?) CU-100 compressor and other necessary gear to have a functioning fridge, and it improved the quality of life significantly. When I bought the boat, the fridge didn't work. However, the original owner had installed an auxiliary battery with a separate Sentry brand battery charger. There is a switch on the panel to switch from the regular house batteries to this smaller, Group 27 auxiliary battery. The idea being that when at dock and connect to shore power, the switch is set so that the fridge is powered from the Group 27 battery, and if the marina loses power, then the $100 battery is ruined instead of the $1,000 battery bank.
This has worked fine since I had installed the new fridge, but the Sentry battery charger seems to be failing. The charger is no longer keeping the Group 27 battery topped off when the boat is connected to shore power. So I'm thinking I have to get a new charger for this Group 27 battery.
But then I read the thread about a low voltage disconnect (never knew there was such a thing), and someone recommended the Blue Sea m-LVD. This makes much more sense to me. And before anyone mentions this, I did read the manual on the CU-100, and it DOES cut off the voltage at a certain point, but it's something like 10.4 volts, which is way too low of course, and there doesn't seem a way to adjust it.
Anyway, I looked at the schematic for the m-LVD, and it appears to go on the positive cable between the battery switch and the panel. But I have two, thick house battery cables, as shown in the attachment (you can sorta see the "house" label on the cables on the left side of the image). How would a person install the m-LVD in this setup?
I'm not the most handy person, and don't have years and years of experience with boat systems such as this, so it may be a simple matter, but I am mystified.
My house batteries are two 4D batteries.
Any insight is greatly appreciated!
