Mechanical Advantage - MA
Sep 22, 2018
1,869
Hunter 216 Kingston
One key point - the lower block 8 is not providing any advantage. Both lines are just tied off onto it; the lines are not running through it.
I found that confusing as well, why waste the cost of a double block where a sturdy padeye would have done the job?
What doesn’t make sense is if I take the weight of the board which I think is 150lbs as the load the system needs to handle and for the sake of argument, accounting for friction and to make the math simple etc lets say the system makes the load “feel” like 15 lbs or a perfect MA of 10 or 1/10th of 150lbs.Thats a lot less than @JimInPB measured???
I have a few ideas on that:
1) When you lift the board, especially when it's fully down, you're not only pulling the board up, but also pivoting it back. Since the line is vertical (or nearly so), you lose efficiency due to the force vectors involved between the line, gravity, and the CB pin opposing some of your pull.
2) There could be excessive friction somewhere in the system. Was Jim measuring the force needed to lift the board, or to hold it static at some height? In a frictionless system those two should match. As friction increases the force needed to hold the board static will decrease, and the force needed to lift it will increase.
3) Are we sure Jim's rigging matches the diagram? In particular, if someone rerigged the lower block 8 and actually used it as a block, with line 1 running through it, down to block 5, and back up to block 7, that would be quite bad. Block 5 would put half of the weight on each of the two legs of line 1 that go through it. Block 7 would be pulled all the way to the left, binding against blocks 8 and providing not mechanical advantage. So all you'd have is 2:1 from block 5, and lots of friction from blocks 7 and 8 binding.
Sep 22, 2018
1,869
Hunter 216 Kingston
All valid points although I would be surprised if its 3) as my interaction with @JimInPB have left me with the impression he’s a smart dude.
This all started with trying to help a fellow 216 owner in the UK
https://forums.sailboatowners.com/index.php?threads/216-hydraulic-keel.197551/#post-1548838
This got me thinking I should have some plan in place to deal with a failed Sailtec unit. I got Googling and trying to remember my HS physics as a mental exercise (gotta work out the brain to keep it in shape ;)) and I got stuck trying to get an accurate answer on MA. Turns out that the “correct” answer seems to have a lot to do with how one visualizes the system.
Jim26m
Apr 3, 2019
579
Macgregor 26M Mobile AL
All depends on the relative locations of the pivot point, lifting point, and center of load of the board. A moment arm could multiply the force required to lift the board - depending on where the cable is connected. You really need a diagram of the rest of the system to analyze it properly. So far, the discussion has been limited to an analysis of the block and tackle.
Also, @Jackdaw 's point regarding friction/misalignment in the system will always prevent us from achieving the T=L/MA nirvana which we seek...
As @Davidasailor26 points out, the force will likely vary based on the angle of the board.
Excessive corrosion at any of the blocks (basically negating the MA) could increase required lifting force significantly.
1,165
Leopard 40 Jupiter, Florida
Sorry, this is not a matter of opinion, it's simple physics. Ignoring the (valid) points that @Jackdaw made regarding friction. There is no way to come up with an odd number of mechanical advantages from a moving block system. As @Will Gilmore stated, the non-moving blocks do not give mechanical advantage, only change line direction. The only thing that counts is the blocks that move with the load. If you have a single moving block, it gives a 2:1 advantage, regardless of the direction that the eventual line goes. If you double the moving blocks, it gives 4:1, and multiplying the moving blocks by the 2:1 gives a 8:1. There's just no way to give an odd number. This pull goes to the last moving block which doubles the mechanical advantage of the entire first set.
Jim26m
Apr 3, 2019
579
So, for the block and tackle, your answer appears to be MA=16... right?
The other part of his question is, if the board weighs 150lb, why does it take 60+ lbs of tension to raise it with a MA ~16? So, the question has evolved from what is the MA - to what is it, and why does it act like ~2?
Nov 8, 2010
11,386
Think you're right, I was not account for the fixed blocks!
1,869
Hunter 216 Kingston
it's simple physics
Well maybe "simple" for you and likely lots of others - me not so much! :) Your explanation of only the moving blocks driving the MA number really strikes a chord with me as it vastly reduces the complexity of the diagram. Find the parts that move and how they relate to each other - relatively simple.
@Jackdaw image of inches of effort - work also works for me as it makes calculating the length of line required in a system something I can get my head around.
Jim26m
Apr 3, 2019
579
So, if this is the correct image, you can see that the MA is largely undone by the connection point of the lifting cable.
Exactly. You're not just lifting the weight of the CB, you're pivoting it with a relatively short lever arm.
Likes: Jim26m
Apr 5, 2009
2,819
This is not true. You get odd number of MA when the moving block has a becket. In this case the moving block is a quad block with no becket so 8:1. If it had a becket so that the terminal end of the line was on the becket you would have 9:1
jviss
Feb 5, 2004
6,748
Tartan 3800 20 Westport, MA
Not so. You can reeve to advantage, have the fixed line attached to the moving block, and get an odd number for mechanical advantage.
That said, I'm thinking my original assertion of 18 might be incorrect; but I have to draw a diagram. :)
Sep 22, 2018
1,869
Hunter 216 Kingston
I'm not sure what this hand drawn diagram is referencing - all the other diagrams are professionally drafted with a legend, this one not (or at least that I can see). It may not even have anything to do with a Hunter 212 but accidently ended up in the 212 manual. However your point about the connection point makes sense to me.
I've never seen a H212 and likely never will so can't comment further. The "system" must have been OK or the original purchasers would have caused a ruckus!
My original ask was to help me understand how to determine the MA of a "complex" system. The system used on the H212 is definitely on the upper end of complex proven by the ongoing debate.
Personally I'm learning a lot. Lot of smart people on this forum and I'm better just by participating.
Likes: Jim26m
Jim26m
Apr 3, 2019
579
It was the first 212 owners manual I found. Thought the sketch was weird, but it looked similar to other info, so it's probably in the neighborhood. I don't own one nor have I seen one either.
But the above discussion has been fun! Thanks for bringing it up.
Apr 16, 2017
841
Federation NCC-1701 Riverside
Was gonna suggest the "Riggers Handbook", but this leads to a bunch of great sites including wikipedia that have better demonstrations.
Google search
Johnb
Hunter 37-cutter Richmond CA
Even if Wil Gilmore , Hunter216 and Jim26m liked the above it is wrong.
The right answer is 17.
Read and understand post number 12 above.
Likes: Jim26m
jviss
Feb 5, 2004
6,748
That's a compelling argument, "I'm right because I said before what the answer is."
I don't buy your calculus. Do you have a reference for that method of analysis?
