If this gets opened to opinions, it will turn into a mess.. You should try and find a reference that agrees with your opinion next post.. If you cant find a reference, good chance its not science or not true.
A very good chance it isn't either science or true.You can still give your opinion or give conclusion that you came to on your own, but you either have to note that its something you came to on your own or give a reference that agree's with you.
I do have doubts, or at least, am skeptical about the greenhouse effect. Greenhouses don't work that way, so, at the very least, it's a misnomer. Greenhouses actually work by trapping warmed air which that it continues to warm without dispersal into the rest of the atmosphere. The idea that light energy can pass one-way through a gas then to be bounced back when it tries to pass the other way through that same gas seems more than a little odd to me. I'm not saying it isn't a thing, but, for me, like quantum theory, I don't understand the explanations I have read. Showing me the math only convinces me that one can describe its effects, not explain its mechanism.Im not sure if someone needs proof that CO2 is a greenhouse gas.. pretty basic physics with lots of references if needed
Of course not.Will, I hope you dont mind if I neither read or respond to your post without references.
I could not find anything in your post showing CO2 concentrations. One plot has some sort of CO2 reference but no scale or anything. Is this this the source you are presenting for your conclusion????? I have provided a plot of what CO2 concentration from about 1975 (refercenc https://www.climate.gov/news-featur...ate/climate-change-atmospheric-carbon-dioxide). This plot is typical of what you can find on the internet. Your plot (which has no description or scale or anything) does not resemble any plot of atmospheric CO2 concentration I can find. Who knows.. cant tell from your reference..Global CO2 Power is shown above from SABER.
CO2 concentration means nothing to Solar Heat Retained.
It is POWER or HEAT...
Reference...
POWER
According to the State of the Climate in 2017 report from NOAA and the American Meteorological Society, global atmospheric carbon dioxide was 405.0 ± 0.1 ppm in 2017, a new record high. Between 2016 and 2017, global annual mean carbon dioxide increased 2.2 ± 0.1 ppm, which was slightly less than the increase between 2015 and 2016 (3.0 ppm per year).
Read and click on POWER link , now in BLUEI could not find anything in your post showing CO2 concentrations
http://saber.gats-inc.com/images/wn_0317.pngCO2 concentration UP... CO2 POWER or heat retained going down.
Hmmmm?
What? Perhaps.Im not sure if someone needs proof that CO2 is a greenhouse gas..
You could have easily fact checked this. Im not sure why LA traffic was mentioned unless you know exactly what percent of the total emission it is.Would a large volcanic eruption produce CO2 equal to - less than - or greater than the CO2 produced by cars in a year of LA traffic?
Human activities emit 60 or more times the amount of carbon dioxide released by volcanoes each year. Large, violent eruptions may match the rate of human emissions for the few hours that they last, but they are too rare and fleeting to rival humanity’s annual emissions. In fact, several individual U.S. states emit more carbon dioxide in a year than all the volcanoes on the planet combined do.
1. IR scatters repeatably upward through layers of the atmosphere until at between 5-9 km the air is so thin that the the atmosphere becomes transparent allowing CO2 emissions here to radiate out into space. At these levels there is little water vapour and CO2 dominates the energy loss. As CO2 concentrations increase so this level shifts to higher levels in the atmosphere since a critical density must be reached for the radiation to escape. These levels are colder (until we reach the troposphere) and IR loss is proportional to T**4 (Stefan Boltzman’s law). This means that slightly LESS energy is radiated to space than before and since the total energy must balance, the Earth warms up to radiate more heat to compensate. Don’t forget that there are windows in the IR spectrum with no absorption other than water vapour allows extra energy loss through evaporation and IR emission from clouds. Clouds also increase albedo. The vertical concentration of H2O and clouds are both temperature dependent. The temperature profile of the atmosphere is called the (adiabatic) lapse rate and is approximately -7 degrees per km falling to -4 degrees per km in the tropics. This is valid up to the Tropopause after which temperature rises again in the stratosphere. So greenhouse warming depends on falling temperature with height, and the anthropic enhanced greenhouse effect due to CO2 emissions is equal to the reduction of IR emissions to space in CO2 bands from the upper troposphere.
Your first post makes a conclusion and has no reference at all. Without a reference, should you have not said this is just your opinion.As you may be aware, much of the consensus work was/is the result of grants issued by agencies and sponsors with the objective of developing supporting science for that view. In other words, most if not all sponsors have been remiss in requesting proposals for science in opposition
What field were you in?I am a retired academic but not in science related to this issue. However, as such, I am very familiar with the process of researching a scientific topic.
I wonder about this query. Will this in somehow impact the relevance applied to submissions of this individual? I hope not. Weather academic endeavors were in basket weaving to applied mathematics should not color the observations of the individual. Opinions are just opinions and they may have foundations in the subject matter. They do not need attached “certifications”.What field were you in?
Note.. this is just my opinion, may not be accurate. I dont have reference.. Im probably not that open minded any more, and if you have a good reference on a related subject, be happy to read it. At this point and after reading stuff for a few years (discussion like this are a good way to learn if you actually spend the time to read and understand links), I dont have much doubt that we have caused the current warming. I think there is a fair amount of deception going on especially on the internet and social media and you can usually follow a $$ trail back to oil, gas and coal funding. I expect that deception to increase in this next election cycle,open mind about the subject
