Doesn’t that describe most sailboats?...one could be a in world of hurt out on the water with a mast that won't go up or down.
A picture of my ex-wife will help with getting it back down.OK, I understand a shot of Viagra to get it up, but................???????????
I was thinking if the mast was part way down, and jammed. How about if you are coming in ahead of a storm, and the mast will not retract. The bridge that you need to go under does not raise, and there is no place to dock. You would not have chosen that location for safety if you weren't counting on being able to lower the mast.Doesn’t that describe most sailboats?
Well sure. There’s always that!I was thinking if the mast was part way down, and jammed. How about if you are coming in ahead of a storm, and the mast will not retract. The bridge that you need to go under does not raise, and there is no place to dock. You would not have chosen that location for safety if you weren't counting on being able to lower the mast.
How much did the old rig (spars and standing rigging) weigh compared to the new one you’re testing? And how tall is the fully extended mast? Do you have more pics of it sailing and trailering?All good questions but sorry it's been thought of. The vessel has been given to 6 different people to keep for 12 months to break and punish. The only problem has been the battery connection was loose on one user. I have looked at the weight issue of the mounting plate and its 3.8 lbs of added weight at center or CL. The mast actually will be lighter than the original mast material. Think about the older fishing rods, they were mainly manufactured as solid fiberglass and heavy. Today, are hollow core except where it's needed 3.5" to the tip. still hasn't stopped anyone from catching fish! Personally and professional, I have worked with a lot of Dr. Iwantobees in my career only to be met with their thinking "inside" the box and not out.
Best regards Capt. Rob
So, what's the point of sharing any of this? When the patent is granted and you are ready start a business to produce these expensive masts for an extremely limited market, come talk to us or look for funding from Indiegogo, Seedinvest, or the other crowd funding sources. Until you are ready to make this public put your ideas to a real test, you are just blowing smoke and selling snake oil.That's all I can share of this at this time.. Capt. Rob
There are many more inconsistencies than that. Besides, the photo is a fake.@StargazerP303
How is it superior to a Gunter rig with a sliding jaw?
That photo shows a less than 20 foot boat. Not a boat with a 40+ foot mast.!?!
I think you’re pulling our leg!
That would be the polite term for it.We are being trolled...
Well that was my thought. A low resolution photo of a distant boat with loose "shrouds" that had sharp corners. Looks photoshopped to me.Besides, the photo is a fake.
