I am putting a permanently mounted fuel polisher together with a Racor 500 FG as the filtering element, I intend to tap into the generator fuel lines feed and return and divert to the polisher when desired. The question I am tussling with is whether to insert ball valves or check valves on the generator and polisher lines so they never interfere with each other. Seems simple and straight forward, but is one way superior to the other. Several options are available for the valves and it seems that the check valves would flow or block without any action. Simply powering up the polisher pump would move fuel through the filter with no pressure or suction on the gen lines. Overthinking can be as bad as under. Opinions and alternative ideas welcome!
