Has anyone installed the spreader repair kit offered by the forum store (sold by US Spars)
It comes with an aluminum reinforcing sleeve and a wrap around spreader bracket.
I could press the aluminum sleeve onto the mast from the front but the wrap around bracket doesn't want to go... To me the correct way to install this would be to remove everything off the mast from the spreaders up and then slide the wrap around bracket down the mast into position.
This would be a tremendous amount of work to drill all those rivets and remove all the upper fittings and items (like mast head, halyard exits etc... etc....). I called US Spars and they said to beat it on from the front with a mallet. The part is a cast part and Im afraid it will break if I try to spread it around the mast like that. or even collapse the mast from the compression from the bracket.
anyone already been down this road ????
thanks
James
thanks
James
