$75 worth of hose clamps?!?!? $@*!$#
Mar 26, 2011
3,418
Corsair F-24 MK I Deale, MD
Just remember to close the sea cock when you aren't on the boat. That solves a LOT of problems. This isn't a huge live-aboard, it's a 22' boat.
Mar 23, 2018
63
Catalina 22 12491 Lake Charlevoix
Are you sure about that?!?!?!? :confused::confused::confused:
Unless I'm missing something, if I closed the sea cock, my scuppers will fill with water. With no where for the water to go the cockpit will fill up, which would then over flow the companion way, which would then begin to fill the boat with water, until it eventually sunk. :yikes: :mad: :cuss::banghead:
Or am I missing something??? :confused::confused::confused:
Likes: Minnesail
Mar 23, 2018
63
Please keep your thoughts and ideas coming. This thread has been great. I really really appreciate the replies. :clap::clap::clap:
:beer: :);) :pimp::yeah:
greg_m
May 23, 2017
692
Catalina Jaguar 22 Simons Town
Man I'm so glad I do not have any through hull fittings except for the keel lifting cable! My sink will be a simple bucket that gets emptied overboard when no one is looking!
My boat had three through hull fittings and only the one draining the galley had a valve. The cockpit scuppers were directly connected to the through hulls. Reinforced PVC pipe and crusty clamps was all that kept the water out!
Based on above discussion and plumbing it actually now makes more sense to have the three through hulls. Eliminates all the t-pieces. It does however raise the need to isolating valves for all three drains.
Part of our boat safety equipment requirements is wooden bungs that fit into the through hull fittings. I cant imagine jumping into frigid water to try slam a bung into a hole!
May 23, 2016
1,024
Catalina 22 #12502 BSC
Scuba, close the seacock to the sink at all times unless using the sink. (NOT the seacock to the scuppers which should always be left open IMO.
I keep a small plunger stashed to push any water remaining in the sink line out past the seacock.
That same plunger gets used occasionally on the cockpit scuppers to keep those lines clear.
Also, install scuppers in the transom to cover you in the event that forward scuppers get plugged up (if you haven't already).
Mine keep clear when in the slip, but when on the hard, leaves, pinestraw can plug up the forward ones.
This thread brings to light the need for brass fittings rather than plastic. I was pretty comfortable with my setup and no issues until Judy brought up the need for "marine" fittings which some of mine are not. BTW, I still don't see the need for double hose clamps everywhere (except the volcano of course!), but that is good insurance.
Here's my current setup, I'll replace the grey plastic fittings w/brass when I can get around to it. The big grey T on top of the black scupper seacock is original to the boat from Catalina....
392
Catalina 355 Boston
Skandvik hose clamps are ABA clamps in a Skandvik box.. The other quality option is AWAB. What makes them superior is they won't fail and sink your boat. They are well worth every penny.
https://marinehowto.com/proper-installation-of-double-hose-clamps/
:plus:
Defender sells a Skandvik kit which also includes a flexible nut driver. Was a great price during the Warehouse sale, but still a good deal if one plans on replacing all of their clamps like I did.
Decided to replace for each hose I touched during Spring commissioning...so all of them :waycool:
You can also get every size individually for a reasonable price...
AaronD
Aug 10, 2014
723
Catalina 22 9874 Newberg, OR / Olympia, WA
Likes: Gene Neill
May 24, 2004
7,131
CC 30 South Florida
Agree with Stu, replace those that are hard to get at with the high quality clamps and use the lesser quality clamps for the rest as long as you inspect them frequently. $75 of clamps are a better safety item than installing a backup bilge pump.
ToddS
Sep 11, 2017
248
Beneteau 373 Cape Cod
I agree with all the advice given... no PVC in that application, reinforced hoses, double clamps, and most of all... When I inherited my first boat and didn't know any better, I DID go for the hardware-store "stainless" hose clamps... which despite being clearly labelled "Stainless Steel" ended up being stainless BANDS with regular old steel screws inserted... after a year or two the screws started sticking/seizing... a couple years after that the screw heads were reduced to lumps of rust... any attempts to adjust with either wrench or screwdriver resulted in the heads popping off the screws with frighteningly little force applied. Presumably if I hadn't replaced them with real 316 marine stainless clamps when I did, another year or two and they would have just fallen right off on their own, sending the boat to the bottom of the sea. Job number one of your boat is to keep the water on the right side of the hull and on the right side of those hoses... good clamps and hoses are money well spent. I'm a cheapskate at times, but wouldn't cheap-out there.
Likes: DrJudyB
Mar 23, 2018
63
$75 worth of hose clamps have been ordered. :)
My ball valves are both RC Marine like @rpludwig It appears it's the predecessor to Forespar's Marelon. Any issue installing a bronze tee into the top of this valve, then installing Marelon barb fittings (tailpipes) into the bronze valve? Would the nipple connecting the ball valve to the tee be bronze or Marelon (if that even exists)?
To do like @Minnesail & @AaronD would be a much larger project. Much more than I need to bite off at this point in time. But they both look great!!! :clap:
I would love to see pics from anyone who has a mix of Marelon and bronze, especially if you have a functioning sink drain.
Likes: Minnesail
Mar 23, 2018
63
At this point I'm still a bit stumped on how to proceed on this project. Hose and hose clamps is about the only thing I'm settled on.
My concern is this turning into a huge project. I want to do this correctly, but do not want to do something where I end up having to replace either the thru-hull fitting or the current Marelon ball valve, or both. I'm afraid, if I try to remove the ball valve, inorder to replace it with bronze, I could potentially loosen the thru-hull such that it needs to be resealed/replaced. I'm looking for a simple safe solution, that avoids that possibility.
If I can, correctly, join a bronze tee to the Marelon ball valve, all my problems are solved. I'll simply attach an additional bronze tee to the first tee, with a bronze nipple. Install bronze or Marelon barb fittings. Install my reinforced tubing, and tighten it all down with my shiny new hose clamps.:yeah:
My question seems simple. How do I correctly and safely attach a bronze tee to a Marelon ball valve? What material do I choose for the nipple? Bronze? Or is this simply not possible? There does not seem to be a Marelon nipple available. :( :banghead::banghead::banghead:
Surely, I'm not the first person to run into this problem. There's 12,000 other people with the same plumbing arrangement. :confused:
SFS
Aug 18, 2015
2,070
Currently Boatless Okinawa
Why don't you give the Marelon folks a call, forearmed with a picture, preferably showing enough detail/numbers for them to know what you have?
Ward H
Nov 7, 2011
3,653
There is a comment on the Marelon brochure about being compatible with bronze fittings but do call Forespar Tech Support. I spoke to them three times while putting together a parts list for changing out my Marelon thru hulls.
ref: perforated hose clamps
I recently read, probably on a vender's web site, that perforated hose clamps "grab" in the perforations preventing the clamp from evenly clamping the hose. None perforated clamps will "slide" on the hose while tightening. sThis allows better and even clamping force around the hose.
Never heard it before. Ad propaganda or is there some truth to it?
Jun 2, 2004
3,399
True but not to the point where it makes a difference for this type of application
