As usual I am in uncharted areas. I am just reporting what is happening. What I am doing could fail.
I have mentioned before I am using Get Rot and saw dust to see if I can make the motor mount good enough so I do not have to gut it and put in new wood like others have done.
I did some checking and found it is generally ok to allow epoxy to get too cold and it will come back to life and harden. Yes there are certain negative effects, but that should not be a problem for this use. I am mentioning this because it got colder a bit quicker then the epoxy set (it is designed to set slow with Get Rot). So 3 weeks later the sawdust mix with Get Rot was still fairly soft.
So I remembered, Duh, get out the goose neck lamp with a 100 watt incandescent light bulbs (am I allow to use them?). Well this got it toasty and today I checked to find the saw dust hard as a rock.
Now the piece of wood was still damp. This dampness inhibits the epoxy from spreading further, it was in the manual, so I realized I should do something more. I drilled a few more holes and figure the 70 degrees (when 30 out) to 90 when 40 outside would help dry it out more.
After a couple of weeks of heat and holes the wood has less moisture.
My plans are to let the lamp stay on the area for a couple of weeks longer. Then wait till we will start seeing more days in the 40-50 range to do the next step.
I plan on using small drills to drill out some from the vent holes radially. Then let the epoxy saturate the areas. With the temps being cold I figure the epoxy will stay wet longer and capillary action will take it further into the wood. Once it has set well I will drill a few test holes and see how hard the wood is using large pins.
I am also thinking some kind of safety cable to the engine just in case.
