I managed to upload a couple of photos from under the cockpit yesterday. Interesting. The crack goes through the ply in an (almost) straight line. One of the photos is a little blurry but others close in indicate that the areas around the crack is wet. Not so. Kept in super dry indoor storage all winter. Possibly some PO had injected resin ?? I think my plan is to clean the existing underside of the existing ply, then laminate a new ply under, with structural beams (I like those preformed ribs from Jamestown). Then, remove the area around the crack on the upper side and replace per Gene and Jacktar's excellent repairs.
