I knew my boat would need a bit of work on the centerboard when I bought it. It was a bit more than expected but still nothing horrible. It looks like it bottomed out and cracked the bottom of it. From there water leaked in, rusted the steel plate which expanded the leading edge. This board was replaced 10-15 years ago. As you can see the manufacturer didn't do a great job when they made this one. Lots of bubbles and voids but I dont think this lead to it's demise.Should I grind away the rust or leave it as is? I'm trying to leave some fiberglass in place so that I can match the shape of it later. I'm guessing that I'll do it in sections. Should I use filler and cloth on the leading edge or would it be stronger if I just used cloth? The bottom of the centerboard seems to be just filler with no cloth. Should this be ground down and given a cloth shell? Does anyone have any tips for getting fiberglass to kick faster when working with small batches?
