Obtaining Wave Period via SailDocs
Feb 3, 2009
294
Knysna 550 SE Knysna, South Africa
Is there a parameter that you can send to saildocs to obtain the wave period? I specify WAVES and WAVDIR, but this doesn't appear to return the wave period.
-- Geoff
Sumner
Jan 31, 2009
5,254
Another alternative might be Windy and Wind Finder. I've used both on our trip. With Windy there is a place to click to see height and period. Wind Finder is suppose to display it but I couldn't figure out how. I also used..
http://www.marvsweather.com/mbw/report_link1.html
... a lot and when all three were pretty much on the same page then things probably ended up close to what they predicted, otherwise there was some distance between predictions and reality,
Sumner
1300 miles to The Bahamas and Back in the Mac...
Endeavour 37 Mods...
MacGregor 26-S Mods...http://purplesagetradingpost.com/sumner/endeavour-main/endeavour-index.html
Mac Trips to Utah, Idaho, Wyoming, Canada, Florida, Bahamas
Nov 8, 2010
11,386
Sumner
If he's asking about Saildocs I assume he will be offshore and getting GRIB files file via slow and expensive sat phone data. No place for browsing.
To the OP, I know that not all weather models (or services) have period data.
Jul 27, 2011
5,203
Bavaria 38E Alamitos Bay
-- Geoff
Did you try PERPW or PERSW? Period primary wave; period secondary wave.
Apr 8, 2010
2,251
I find that a site dedicated to wave period is a great help.
Surfers, as a group, want this exact info.
They use a site called (laugh if you will...)
magicseaweed.com.
It has been quite useful to us for near-term info on inshore sea state for making deliveries up and down the Washington coast for many years.
capta
Jun 4, 2009
5,100
If you are headed out into the Gulf Stream, don't rely on any weather forecast system. The Stream does not follow any rules that I know of other than the peak flow is the hottest water.
Feb 3, 2009
294
This was the answer that I was looking for. I don't know if I get back the secondary wave data, as my program doesn't dispay it, but I do get back the primary wave period. Thank you!
P.S. This is for use via an IridiumGO satellite connection and in locations where there's no Internet, hence the reason for using SailDocs.
