S S backing plate info
Jun 11, 2004
1,935
Oday 31 Redondo Beach
Gonna use 3/16 or 1/4 SS plate, liberaliy apply fresh 4200 to it when placing against the hull. What say you all to that?
I think either the 3/16 or the 1/4 will last the rest of your natural life.
Oct 10, 2011
619
Tartan 34C Toms River, New Jersey
Wow sure is a lot of conversation for a backing plate.
By the way have fun cutting 3/16 SS unless you have a good band saw.
A few years ago, we had a thread on pressure washing that went on for several weeks. It really took a weird detour into amputated toes, blood poisoning, lost eyes etc. It went way past ridiculous and just kept going.:eek:
If you truly want to poke the bear, start a thread on "Do you always wear your PDF or only in bad weather" thread.:dancing:
Likes: sailnoproblem
Jul 13, 2010
1,100
Precision 23 Perry Hall,Baltimore County
Or complain about your anchor!
Mar 26, 2011
4,014
Corsair F-24 MK I Deale, MD
1/8" will last the rest of his life.
The washer that bent were probably 0.042" Do the math, and you will see that anything over 1/8" SS or aluminum is wasteful; the bolt will break before it bends. (I've done lab testing on this). Extra Thick washers are 1/8", for this reason.
Likes: DrJudyB
Aug 22, 2017
1,609
Hunter 26.5 West Palm Beach
You wear yours in bad weather???? That's when they are most uncomfortable.:biggrin: (we don't seem to have a poking-the-bear emoji)
Likes: rgranger
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
Don't just slop epoxy on there to fill in the depressions. Take the time to do it right. Sand off the surface to get to raw laminate, then mix some epoxy and fill it with chopped strands of glass, just take some glass cloth and with scissors cut some strands off to get a very thick paste that won't run when you mix it all together. Coat your backing plate with wax or other release agent then put the thickened epoxy in the depressed areas and using release agent coated bolts bolt the backing plate in place until the epoxy hardens. Once in place clean up any that oozes out. Once hardened you will have a nice flat surface for the backing plate to permanently mount against. Seal the assembly from the outside as previously mentioned in this thread. Water pressure tries to push the sealant into the joint. If you seal the inside the water pressure tries to push the sealant out of the joint. Plus the bolts are then sitting in water that is not refreshed causing crevice corrosion. 3M 4200 should work fine.
