Hello all,
So completed holding tank co version. Beneteau has such a tight under the sink area plus used an over complicated amount of hoses and thru hulls. So I removed the macerator pump and reconfigured to gravity fed holding tank. Now bottom of tank fitting (original deck pump out) goes directly to a thru-hull fitting about two feet away. Then I connected the deck pumpout to the old macerator fitting that has a pvc pipe running to bottom of tank. I oriented the pvc pipe directly above the bottom of the tank gravity fitting so if there is ever a blockage I can put a hose into the deck pump out port and flush it out. Also with this upgrade I was able to eliminate 1 thruhull fitting and get some additional under sink storage space (have to relocate shower pump next). 1 project down......
