LOL that is several hundred dollars worth of flex tape to "seal" that boat.A little Flex tape should do it!
John,I'm not sure I would try this in the water ever, but like thinking what ifs.
I like to get mine done in a less time consuming manner (while in the water) and the piece of pvc or tubing really isn't much to fiddle with. It's a good method to seat one ring before putting in the next. But of course whatever works for you is the way to go.What happened to just screwing in the nut with several rings of packing at a time? Perhaps a bit more time consuming, but fewer things to fiddle with.
This allows you to seat the first couple of rings in without turning the nut or using a sharp object to seat it. My nut is fairly deep so I need something to push the first couple of rings in.What happened to just screwing in the nut with several rings of packing at a time? Perhaps a bit more time consuming, but fewer things to fiddle with.
