Exchange GPS antenna on Hunter 45CC
May 27, 2004
2,059
Viktor, if you mean "how to replace" your GPS antenna, it would be helpful if you could post a picture of the unit. They are probably available on the store at this web site or from Defender.com online.
If no picture is available, a brand name or detailed description of your current unit could be helpful in guiding you to a source.
If they look like the pics below, it's a matter of how it mounts on your boat and how it connects to your display.
Hope this helps.
182
Hunter 45cc Florida
You are going to have to remove the trim board from inside the aft cabin in order to gain access to unit and cabling
May 27, 2004
2,059
artboas, Thank you for your question. Not knowing the unit, I would not have known about the battery.
Sep 5, 2009
136
Hunter 45 CC Marina del Rey
My electrician did not want to remove the trim board. He fastened the new GPS on a plastic ring mounted on the deck - work well!
Best, Viktor
