Commissioning Commitments
Phil Herring
Alien
Mar 25, 1997
4,918
- - Bainbridge Island
Its just about time for our friends in the midwest and northeast to cut away the shrink wrap, flush out the pipes, re-install the battery, and get to work!
Do you have any projects on your commissioning to-do list this year? Or will you just splash and dash?
May 1, 2011
4,261
Pearson 37 Lusby MD
In addition to the normal bending on sails and re-installing canvas, had to replace the mast boot tape this year.
Mar 11, 2009
199
Hunter 40 Saint John
I'm trying to decide if I should move house batteries from master stateroom, under bed, to under Nav station in main salon. I always seem to have low voltage issues and am wondering if I decrease then distance from about 20 ft to 5 feet would help do the trick. yes I do know about the Voltage drop across AWG #10, which isn't very much, but just curious if it would be worth the effort??
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
Biggest project for me:
I installed a new backstay mounted radar late last season, and its not pointed perfectly fore-aft because of the angle of the pole base mount to the transom. Now I have to figure out the angle, create a wedge shim to correct the angle. 20 minute project which will probably take a day...
Tried to do it with the boat in the water while leaning over the transom last year, not a good way.
@jdhohmann Your question and solution generates more questions in my mind.
First what do you mean “Low Voltage. Issues”. How low? How measured? What is affected?
Quantifying your battery / voltage issue may provide clues as to the cause. It may be the location, it may be the wire gauge. It may be your charging sources.
Battery location can impact the balance of your boat. Are the batteries centered in the boat under the berth? If moving them to the Nav Station will this induce a list to one side? How big are the batteries and how man are you talking about? Will you need new wire?
These are just a few of the questions that I would consider...
Likes: jdhohmann
Feb 6, 2013
437
Hunter 31 Deale, MD
1. Finish sewing new salon cushion covers.
2. Sew new bimini boot.
3. Go cruising for a week (alone) in early May.
4. Remove jib and take it home to install new sail cover during MIL's visit during which I'm told I can't go to the boat.
5. Stop procrastinating.
Jul 7, 2004
8,404
Hunter 30T Cheney, KS
It was gorgeous this weekend and the lake is full. Lubed my winches and waxed the hull. One more coat of wax and I think I'm ready to splash her!
"Doc" was flying this weekend. She was in sight of the boatyard but never close enough for a good picture. Doc was a Wichita volunteer restoration - https://www.b29doc.com/
May 23, 2013
54
Hunter H42 Passage East Chicago and Hammond
Where do I begin?
1. Blast bottom, sand, bottom coat and paint.
2. While mast down-rigging inspection, run new cables for electronics, mount new antenea, new wind indicator set, 2 new halyards, etc.
3. Replace lead acid house batteries with new AGM batteries.
4. Repair the broken bath tub fitting hidden behind the house batteries (admiral wants to take baths)
5. Instal sonar.
6. Perform leak tests on both water storage tanks.
7. Instal a better condensate drain on forward AC unit.
8. Remove and re-bed forward hatch.
9. Run a water pressure test to check for any leakage on both heads to holding tank.
10. Measure, cut, bend and sew for new Dodger.
Ugh I never going to get back in the water!
Sep 24, 2018
2,617
O'Day 25 Chicago
  • Finish installing new bulkhead
  • Service engine- Waterpump, engine-hull seal, fuel filter
  • Install Bimini
  • Fix fiberglass on leading edge of centerboard
  • Fix freeze crack in keel
  • Figure out how to use head
  • Buy a dinghy (anyone have a spare?)
NYSail
Jan 6, 2006
3,064
Beneteau 423 Mt. Sinai, NY
Priorities....
New a/c vent hose forward cabin
Make forward holding tank gravity fed and eliminate 1 thru hull fitting, macerator and associated hoses
replace wash-down pump
Sand, refinish and re-calk toe rails (wife)
Drop mast to run new antenna cables, new running/deck light, adjust rig/spreaders
Boat goes in water mid April.....
Nov 8, 2010
11,386
Team BlueJ creates two lists, a pre-splash and a post splash list.
Pre:
VC17 bottom paint
Topsides buff
Hullkote waterline and rudders (edit)
Replace main sheet masthead sheave
Replace backstay flicker
Swap plug for impeller
Post:
Wire seatalk 2 nmea converter
Wire RaceGeek mast display
Wire new battery monitor
Test fit new carbon jib
Line and check all 4 winches
Dewinterize all house systems.
635
Catalina 25 Sea Star Base Galveston, TX
The weather here has been sailable since late December, but Valiant has a few things that I would like to be done before her next sail.
- Bottom repainted
- New sails rigged
- Tiller restoration
- New sheets and halyards
- Polish and wax the hull and deck
AaronD
Aug 10, 2014
723
Catalina 22 9874 Newberg, OR / Olympia, WA
- Bottom repainted
- New sails rigged
That's only 5 items, but they're much easier said than done!
My list is longer, but much less work:
--Finish internal outhaul
--Route lines and mount organizer / cleats for second reef
--Glass around failing cockpit-pocket joints (hopefully that will eliminate the remaining leaks under the cockpit)
--Mount headknocker on boom for double-ended mainsheet
--Mount improved tiedowns for cockpit cooler
--Install new bimini
--Replace aged-out PFD inflators
--Add line holders and cleats to tidy up lines in cockpit
Likes: Simon Sexton
May 7, 2016
37
O'Day 222 Dubuque, IA
Sailkote waterline and rudders
Do you use the same spray can used on sail slugs, etc? Does it keep algae from growing above the waterline (mine is not exactly at the waterline in places and requires cleaning with muriatic acid every year)? How long does it last - all summer?
Thanks!
I finished bottom painting and replacing anodes this weekend. I'm down to just a few more pre-launch items:
Must do:
- Wash/wax topsides
- Paint transducer
Nice to do time permitting:
- Burnish bottom paint
- 20 hour capacity test of 2nd battery (one done)
- Clean and lubricate winches (can wait until post-launch, but with more risk of donations to Poseidon)
Misc to-do before or after launch:
- Fix the rubber gaskets on the engine hatch that are coming un-glued
- Inspect / lubricate steering cable and chain
- Lubricate Volvo prop shaft seal
- Bend on sails
Nov 8, 2010
11,386
Thanks!
Sorry meant Hullkote. It’s closes pores in the gel coat, smooths the surface and yes keeps slime and growth off for most of the year.
May 7, 2016
37
Thanks - I may have to try it out! Found it on eBay for $20 with free shipping...
666
Hunter 34 Toms River Nj
You guys all seem to behind the eight ball‼
I splashed last week after completing the winter to do list.
This weekend weather permitting just have to put sails back on
And tune the rig. Planning to be sailing by Saturday afternoon if all goes well.
Hope to see you guys out there soon. ⛵⛵⛵⛵⛵‼
Ward H
Nov 7, 2011
3,653
New AC Panel, GI and Smart Plug
New battery monitor
Convert alt to ER and MC614 external regulator
New seacocks
New AP
New instruments, transducers and SeaTalkng network
New fuel lines
Used AC unit
Bottom paint
Wash and Wax
I took on a bit more than I should have this spring.
