Bow Pulpit mounting points
Dug22
Jan 29, 2019
67
Catalina 22 Vincent Alabama, BSC
Does anyone know what the mounting points on the top of the bow pulpit are used for? my lifelines run at an angle to the bottom/front of the bow pulpit.
Jul 12, 2011
1,165
Leopard 40 Jupiter, Florida
Picture?
Catalina probably dipped the last connection of the lifeline so that the sail will set properly when off the wind.
Jul 13, 2015
931
Catalina 22 #2552 2252 Kennewick, WA
my '73 is this what you are referencing? No specific use that I'm aware of-- nice place to tie off a halyard ...
Dug22
Jan 29, 2019
67
I did not think they had a purpose but was wondering why they put them there. Guess it's just something Catlina did...
Apr 11, 2017
571
Catalina C22 Solomon's Island, MD
I think they are just an alternate mounting point for the lifelines - if your jib is cut high enough.
Likes: Doug Doty
Aug 31, 2017
102
Catalina Catalina 22 Tampa
They are 2 different positions for either having high or low cut jibs/genoas. Your lifelines will only fit one or the other.
Likes: Doug Doty
Feb 21, 2019
46
Catalina 22 Madison In.
My life lines terminate here at the bottom in 1975 but he was asking about the top !! I need a picture.. Maybe an optional attaching point...
greg_m
May 23, 2017
692
Catalina Jaguar 22 Simons Town
Here in our marina all the boats that have lifelines have upper and lower lifelines running from the pullpit railing to the pushpit railing. It's only when I joined this forum that I saw life lines being terminated at deck level on the pullpit railing.
So my guess is that the railings were made with this in mind and it's up to the owner to decide what he wants to do.
It was also in this forum that I learned about raising the height of the foresail by using a pendant.
Boats in our boat yard and the green hull/grey deck boat is our sail training L26.
3,651
I think running the lifelines to the upper attachment point would look very cool, and provide enhanced security when changing headsails or working with the anchor. I'd do it in a second, if the sails were cut to allow it. But the180 drifter would need a LOT of its foot cut off, and the 150 almost as much. A 120 on a very long pendant (24"?) would probably be high enough to work, but you'd be heeling a lot at the upper end of the sail's wind range. Plus there's the cost of having the sails recut, and replacing the upper lifeline with a longer one. Too many compromises.
Likes: Doug Doty
