This is the only needed repair I have discovered beyond cosmetics. I would like to hear advise from others so I can consider options beyond what I've come up with. This crack in the headliner only leads out of the front starboard corner at a 45 degree angle about 8-10" Should took a pic but did not while in there. The deck above it walks surprisingly solid and I am a big boy. I am assuming that it is due to water intrusion at the hatch and freezing ?? Your thoughts ??
My current strategy is to pull the hatch assembly and see if I can dig back in there to inspect the wood. I can easily imaging it being bad coring or at lucky best maybe mostly on the under side.. Possible I could dig it out and replace with new material soaked in epoxy. and then treat the inside headline as a crack repair to retain as much original glass work as possible for aesthetics. I will not disturb the top side due to to it still being original and good. I am more lenient at to disturbing the inside as it is less visible but really don't want to work upside down with the epoxy in there. Thoughts ???
