For 2-speed spin winches, it’s not the low gear, it’s the HIGH gear that’s valuable. Not super loaded, but you want it in QUICK to trim and keep the flying shape.This probably sounds like a dumb question. I've used both standard and self-tailing winches, often the safe size side-by-side on the same boat (my current boat is like this--the jib winches are ST single speed, and the reacher/chute winches are standard 2-speed (not sure why--you never put that much tension on a chute).
Does a Wincher actually help? It's not secure enough to use as a cleat, like an ST. It's generally not secure at high load. Self-tailing is nice on larger winches, where you might use both hands on the handle, but on smaller winches you generally pull in most of the line by hand and then give it a few quick turns with one hand. A Wincher makes it slower to throw off the line when tacking. As long as there is a cam cleat well placed, I don't see how it is more convenient or more efficient. Yes, it is a little nicer for small adjustments when single handing, but in that case I simply steer with a foot or work fast; a quick turn takes only seconds. I'm certainly much worse off when the Wincher slips.
I've removed Winchers from several boats. Not a fan.
Let me revise your economics, waiting for the yearly 2 for 1 Lewmar winch promotion at WM will save you $539!Hi Hook
Some economics.................
..............The smallest lewmar ST winch at West are slightly larger and sell for $539 each; That is $1070.
I've only seen them sold in pairs.... and never at that price... for a boat his size the medium or small is sufficient... but even at $50/pair I think they're wasted money.The Barlow rubber winchers sell for $105 each . $210 a pair..
The single speed is 2:1.For 2-speed spin winches, it’s not the low gear, it’s the HIGH gear that’s valuable. Not super loaded, but you want it in QUICK to trim and keep the flying shape.
Yea good call. For some reason I thought I remembered that the 16s split the two ranges. I figured that you'd correct me if I was wrong! ;^)The single speed is 2:1.
The 2-speed is 2:1, 4.2:1
So unfortunately, that does not help. I've never used the lower gear... but I would on the jib, if I had it... but the spin winches arn't self tailing, so I can swap them (and I don't want self tailers on the chute.).
