I'm sure I'm missing something, but I can't find a product that is ready-made for jumping the current from one bus bar to another. Reading a bit further, maybe I'm thinking about this the wrong way! For an unswitched positive bus, I bought 2 common bus bars from Blue Seas, rated for 150A, like this … https://www.bluesea.com/products/2307/Common_150A_BusBar_-_Four_1_4in-20_Studs_with_Cover
Each has 4 - 1/4" studs. I figured that I don't want to stack cables on the studs and I have two 2awg cables coming from house batt and ACR, one 4awg from the alternator switch, one 8awg from the charger and a multitude of 16awg's from various loads that want direct battery power, not through DC panel. Maybe some time I add a solar input. I have MRBF holders for the 4 & 8 gauge cables and the 16's have in-line fuses.
So my question is: What do you use to link the bus bars together if I am using all 8 studs? But, after reading the tech info on the buss bars, it seems that the studs can stack up to 4 terminals, and it may even be better to stack them on one bus bar, rather than using 2 bus bars. What do you think?
I have a 200A MEGA fuse that I planned to use, like this ... https://www.bluesea.com/products/category/15/49/Fuses/MEGA-AMG_Fuses
Is there any downside to using a fuse like this even though it is not necessary? It bridges the gap nicely and is compact. I was looking for a ready-made bar that would link the stud from one bus to the other, but I can't locate any product that seems to do this. I know I must be missing something. I'll want to do this on the negative side as well, where multiple negative cables come together.
If stacking is the better way to go, I simply do that …
