- Oct 22, 2014
- 24,938
No. It is your boat and your choice.am just cranky.
More likely they do things by history
They may just need your guidance.
Anti fouling paints (be they ablative, modified epoxy or other) do not cure underwater. That is not how paint works. Paint "cures" when the solvents in it flash off into the air. This does not occur underwater. Your paint manufacturer will provide label instruction on just how long this takes and I guarantee it is much longer than ten minutes. When you splash a boat with uncured paint, that paint will remain soft and unstable underwater and will soon be scrubbed off. I have seen this thousands of times.I agree with Allen, Paint before splash. If it is ablative paint most will be dry to the touch in about ten minutes. I have touched up the pad areas ten minutes before the boat was splashed and the pad areas have always cured under water.
Sorry, 100% untrue.The ablative type paint never totally dry...
Good riggers will tap on the outside of the hull to locate solid points. Not precise, but not entirely guessing either.Jssailem, in my case the yards have no idea where the bulkheads are. The boat is usually locked when they pull it...Another issue that annoys me is that they sometimes way over-tighten the stands which are only needed to balance the boat that rests on the keel....
I have always felt this must be true, but I've looked at hundreds, maybe thousands of boats searching for clear evidence that the paint failed prematurely where the pads had been. I've never been able to catch a really clear case, only slight variations.When you splash a boat with uncured paint, that paint will remain soft and unstable underwater and will soon be scrubbed off. I have seen this thousands of times....
Probably. But motivation to look through the many hundreds of underwater pix in my files is the sticking point.Pictures?
Probably. But motivation to look through the many hundreds of underwater pix in my files is the sticking point.![]()
?My Catalina owners manual specifies where to lift the boat. In addition, there are tags on the hull that say "lift here". One yard put the forward strap a foot away from the tag, and lifted the boat with the strap on the speed sensor paddle wheel. Fortunately, no damage resulted.Jssailem, in my case the yards have no idea where the bulkheads are.
