My H260 "survived" Hurricane Michael with major damage to hull. See picture. Is this a repair that is possible and how would you recommend tackling it.
My second problem is that after the storm my bilge filled up with salt water and I emptied it every 2 weeks, then it would fill again. I think that the water ballast tank has a leak in it. Now that I was able to trailer the boat and it is out of the water and ballast tank is empty, I have water under the floor in the main cabin. When I stand on the floor and bounce I can hear water under the floor. It apparently can't drain into bilge and is trapped under the floor. How do you get this water out? Do you think the water ballast tank is cracked and water as seeped into this area? Is this repairable?
Thanks for any suggestions.
