In early December I posted about one of my winter projects, Instrumentation. That project would require new power supply cables for auto pilot, chart plotter and SeaTalkng network, each with a different size fuse.
I also planned on installing a DCP battery switch to isolate the house and start battery banks to eliminate instrument dropouts when starting while under sail and auto pilot.
Mounting some DC outlets was also on my list of upgrades.
The original DC distribution panel left a lot to be desired. Push button circuit breakers for groups of circuits, toggle switches that were hard to see if they were on or off, all connected by 10 awg wire and quick connect spade type connectors. There were a few times this past season I'd have to open the dc panel and put back on a quick connect that had come loose and fallen off.
Enter PROJECT CREEP!
I decided I would make my own switch panel. I'd use toggle switches with screw connections instead of quick connects, add circuit on indicators and use fuse blocks for OCP. I studied how Tom Y, Sumner and others built their switch panels to get ideas.
I also looked at the Blue Sea DC panels to see what they had to offer. I kept going back to their 16 breaker toggle style panel. It would fit within the teak frame of the existing panel and look much neater than anything I could build.
Enter more PROJECT CREEP!
After thinking about it over a couple of bourbons, I ordered the Blue Sea panel.
I mounted the new panel right over the old panel. I made a narrow panel out of ABS sheet plastic for two DC Outlets and a Blue Sea Digital volt meter and battery selector switch and mounted it alongside the new switch panel.
To avoid having to have too many various size breakers I installed a 6 individual circuit fuse panel on the back plane. This way I could use almost all standard 15A breakers and run the loads that needed lower amp fuses through the individual fuse panel.
I then installed the new DCP battery switch below the panel. After thinking about how to fuse the new DC panel, I decided on installing a C Series 3 breaker panel I had for another project that never materialized. I put it next to the battery switch. One breaker for the DC panel, one for a future inverter install and one spare.
I left the original AC breakers in place for now. When I'm ready a Blue Sea AC Breaker panel will just fit in the remaining space next to the DC outlet panel and the Blue Sea DC panel.
Original panel
New panel
Now I'm ready to move on to installing the new sailing instruments.
Original panel
New panel
