A fellow boater on our dock pointed out the broken fitting for the roller furling. I had never noticed this and do not know when it happened. It is a schaeffer fitting and I will check into a replacement. Has anyone had a similar situation. I will need to drop the roller furling a few feet to install the new fitting. I have attached the spare jib halyard to the bottom of the plate which holds the roller furling. Since the mast is stepped on the deck and held with shrouds just forward of the mast is this enough safety factor. My basic question is when you do drop the roller furling, what do you do to insure there is no issue with the mast. See picture of broken fitting.
Thanks,
Mark & Joy
Thanks,
Mark & Joy
