- Oct 22, 2014
- 24,797
Terry. It was less than 90 minutes and I was interrupted by grandkids twice.
If your going to attempt it I would encourage you to consider new line. It is a lot easier with new line.
As an alternative you can do a quickie by whipping the line. Strength of a whipped eye splice is like 80%of the line. That is a little stronger than the same as a line with a knot like a bowlin. Knots can weaken line from 20 to 55 %. It is the bend in the knots that do the line in. .
Compromise the nature of boating. If in doubt use a little larger line and tie a knot.
I fine that older lines or lines that are a wee bit short and I don't want to use up line with a splice serve well with a whipped eye splice.
Here is an example of a quick and dirty whipped splice that will serve the purpose I intend. When the splice wears down I will replace. Only step left is to cover the whipping with a little UV protection to lengthen the time before deterioration.
