I know that some of you have solved this problem already but I need some help with it. I would like to place a mast plate/halyard organizer under the mast base on my 1985 Hunter 23. This would allow me to run some of the running rigging back to the cockpit. I ordered the M3 Mast Plate from Garhauer Marine but when I placed the OEM mast base onto the plate I found that i could not get the hinge pins either in or out as they would not go past the ears on the mast plate and unfortunately none of the holes on the mast plate would line up with the hinge pins. So, I ended up sending the mast plate back. For those of you that are not familiar with these parts, I have included a couple of pictures. I know that some of you have solved the problem of where to attach the turning blocks for running the lines aft, so I would really appreciate some help wit this issue.
