That’s what I’m trying to figure out. Despite recent contracted filling, the engine quit on the way out of the marina. (Sailed back to the slip okay.) Turns out, the vent was clogged so fuel couldn’t get into the tank or into the engine. The spiders must have been busy.Is your tank full in that photo?
Clogged vent, Greg. Seems the spiders were busy in there.did you ever figure out the reason for your engine issue?
Just hookup a multi-meter (in resistance mode) between the brass stud and the outer metal case (one of the two screws holding the module down). The red indicator and the internal reostat are one and the same (mechanically tied together inside the clear plastic housing. The magnet (attached to the float mechanism) below moves both the sight gauge and the reostat together.Hmmmm, well mine seems very clean. The brass stud is clean.
I think I will try hooking it up to a gauge and see if it works.
How does that Capsule thing work? And how does it attach to the sight gauge?
@AlastairLC - did you ever figure out the reason for your engine issue? Not out of fuel I assume.
Great. I will test it out this weekend. Worse cas sounds like one of the new site glasses with the capsule that Maine Sail mentioned. Is there more than one size?Just hookup a multi-meter (in resistance mode) between the brass stud and the outer metal case (one of the two screws holding the module down). The red indicator and the internal reostat are one and the same (mechanically tied together inside the clear plastic housing. The magnet (attached to the float mechanism) below moves both the sight gauge and the reostat together.
If you remove the module to test, then you should find a magnet that you can hold under the module and rotate. You should see the red indicator and the resistance reading change together as you rotate the magnet.
Chris
