How cool do you run?
Jan 12, 2016
273
Hunter 410 Ladysmith, BC
Your engine that is...
I've got a Yanmar 4jh2e, and I've never seen the engine warmer than 150-160'F, and normally 130'-140 is where it sits.
I've replaced the thermostat in May this year but no change. Can the cool waters we run in here in the Pacific NW be a reason for the engine coolant temps to be less than 180'F.
What are others in this area seeing when they motor? Especially with a fresh water cooled Yanmar.
My Perkins at 80% runs 150-160 very steady. When I bought her she had issues. I had the fresh coolant pump fail. Had temp over the 200 level and alarm blaring before I could get into the slip. I replaced the pump, and all has been great, no more overheating. I check temps about every 45 minute of running. Check water flow. Even grab the infrared gauge occasionally to verify the engine temp gauge. Trust but verify.
May 20, 2016
3,015
I was running in 180 at cruising speed if I pushed it it temps went up. Last winter I switched from a 2” to 3” heat exchanger and now only hit 150 when pushing it, and cruise in 130-140. I have a 160 Thermostat comming, I suspect a P.O. removed the stat because of overheating.
Les
May 24, 2004
7,226
CC 30 South Florida
Not surprising at your latitude. Here in the Gulf of Mexico during the summer the raw water temperature approaches 90F at the intake and engines run a little hotter. Diesels are heat machines and they run more efficiently when they are hot. Check your temperature after an hour of running at full throttle.
Jan 5, 2017
2,490
My shop manual for Perkins 4-108 calls for a 190-200 thermostat. It was running really warm last year so I rebuilt the heat ex. and put a 180 thermostat in. This year it will run all day at 80% and stay at 180 but runs warmer if it sits at 15-1800 RPM. I'm thinking because of less raw water through the exchanger. (maybe?)
