Painting the bottom will have no connection with internal parts like that pump.Hello All Sailors.
I’ve gotten some good advice from you before, so hope you can help me out again.
I’ve got a Beneteau Oceanis 31. The Bilge pump isn’t removing water out of the Bilge in Automatic or Manual. It tries to pump in manual switch position , the pump pulls some water, I can see water movement in the hose, but it does not drain the Bilge
I disconnected the strainer at the inlet , in the Bilge, and sucked via shop vac from there ,
I’m about to swap float switch, after that I’m out of ideas.
Am I wrong to think the Bilge pumps out the stern area. ? The boat was bottom painted in July so I’m wondering if it’s plugged up. ? Frustrating.
If trouble shooting this, I would start where you did, in general. If the hose from strum box to pump is OK, then it might well be the pump. BTW, those Parr-Jabsco pumps are near indestructible --- out boat came with two of them from the factory.
Having said all that, agree with other sages here that the diaphragm and check valves should be verified. Also, and not an everyday thing, make sure that the existing hoses actually are still connected to the thru hull.
Once you get the pumping going, DO change to a dedicated thru hull for each bilge pump, if this is not the way it is now.
Our boat has three: one huge manual pump accessible from the helm, and two of those $$$ Jabsco 12 volt pumps in the main bilge. (I have helped save one sinking sailboat, and am *unanimous in my opinion that more working pumps are Better.)
* thanks to Mrs Slocum of AYBS......... !
