Hello All Sailors.
I’ve gotten some good advice from you before, so hope you can help me out again.
I’ve got a Beneteau Oceanis 31. The Bilge pump isn’t removing water out of the Bilge in Automatic or Manual. It tries to pump in manual switch position , the pump pulls some water, I can see water movement in the hose, but it does not drain the Bilge
I disconnected the strainer at the inlet , in the Bilge, and sucked via shop vac from there ,
I’m about to swap float switch, after that I’m out of ideas.
Am I wrong to think the Bilge pumps out the stern area. ? The boat was bottom painted in July so I’m wondering if it’s plugged up. ? Frustrating.
