Solo sailing: Dropping Jib
JRT
Feb 14, 2017
2,059
Well a bungee cord, down haul on the jib and not trying to reef sails under power would be the best place to start.
Honestly leaving a tiller unattended and a boat not under control while solo and trying to reef old sails just sounds terrible and unsafe.
Likes: JimInPB
Jun 1, 2004
8,360
Thank you all for your comments. I will have to try some of the recommendations to see how they work for me. The reason I hesitate to put money into the boat is the age (44) and areas of the deck getting soft. I have to weigh upgrades vs looking for a newer boat with roller reefing etc.
Actually, it isn't that much money. If you are concerned about spending 20-30 bucks on your boat for a length of small diameter line and a couple of very small blocks... and a plastic cleat... then brother.... you are in the wrong sport. That's less than you spend on a round of golf and it absolutely solves your problem.
Soft decks are a different thing entirely... and I agree that's a very weighty decision... but a jib down haul is a NO BRAINER to make your sailing safer and more convenient.... plus you can take the gear with you when you get rid of the boat and the new owner won't even know.
Mar 26, 2011
4,063
Corsair F-24 MK I Deale, MD
Instead of hauling the main tight, drop the traveler all the way. The boat will still sail a very tight reach with no helm, but will not do the S-turns since it can't point that high. Try it. Did it on other boats all the time.
Sep 20, 2006
367
Oday 20 Seneca Lake
Problem is I don't have a traveler. The main is connected to the back stay with a diamond plate. Any way to simulate dropping the traveler all the way. (not sure just what this means)
jwing
Jun 5, 2014
503
ODay Mariner Guntersville
I agree, except that I spent about $10 at the hardware store for rope and a pulley to make a downhaul. And I had a bunch of rope left over. No need to get expensive sailing gear for a small-boat jib downhaul.
Oct 3, 2006
1,041
Hunter 29.5 Delaware city
If I want to keep sailing on main alone - head a little downwind on a reach, main well out, tie the tiller off, and take advantage of blanketing from the main! If it was balanced, when you drop the foresail, the boat will start to round up, but not too far because the main isn't sheeted tightly.
Apr 7, 2016
184
Sailboat 35 Sailboat Anchorage
I may be late to the party, but I think your issue is easily solvable. Run a dousing line from hour cockpit to your bow and up the forward stay. It doesn’t have to be a large line since it is just pulling down the sails. Then worst case scenario you run to mast, loosen thebhalyard and get back to cockpit. Anyway, hope this helps.
Apr 7, 2016
184
Check out stingysailor. He has an excellent workup on this and a bunch of other things. You’re probably talking about $100 tops. I’d imagine it is a fraction of he cost of going overboard and leaving the boat unattended sailing away.
FDL S2
Jun 29, 2014
485
S2 7.3 Fond du Lac
A downhaul and a dousing line are the same thing.
FDL S2
Jun 29, 2014
485
S2 7.3 Fond du Lac
Oh my bad. I missed your earlier post. I have a hank on jib so I feel his pain.
No problem. I've never had a boat with a roller furler, so a downhaul was a huge upgrade for me! I got the idea for it from the Stingy sailor and had all the parts for it laying around. But if I didn't have fairleads I would have used pieces of PVC like he did.
Aug 22, 2017
1,609
Hunter 26.5 West Palm Beach
Perhaps I misunderstand my terminology here. I have a spinnaker with a dousing sock. The line on the sock is the one that I call a dousing line. The line that pulls a sail or a spinnaker pole down is something I call a down haul. I see a dousing line & a down haul as different things. Am I off base?
Apr 7, 2016
184
Yeah, I'm with you. But I think I was mostly wrong and you guys were right. I think I made this comment right after watching a spinnaker video on YT. While there may be an exact definition by some salty sailor here, the most important thing is to make sure everyone on YOUR boat knows what you're referring to. Anything has gotta be better than that white line over there with the red thingys in it.
I'm guessing a downhaul could also refer to your boom vang or your spin pole holdy down thing (see what I did there?). But now we are getting off topic.
FDL S2
Jun 29, 2014
485
S2 7.3 Fond du Lac
No, you're right they are different.
I was thinking that in the context of this conversation where we are discussing a line to pull down the jib they are the same thing.
Likes: JimInPB
