Interior Hull Trim
Dec 28, 2015
1,944
My 78 H30 came to me with aftermarket 3/8 foam backed vinyl hull liner that looks to be glued on with contact cement. The glue joints between the foam and vinyl is failing in a couple areas and the vinyl has shrunk in others.
I'd like to add horizontal strips to the sleeping area to spiffy it up and also keep the vinyl up. Not being able to just screw them into the hull, I was wondering what is the common method for installing this type of trim?
Oct 29, 2005
2,366
Cut some holes on the vinyl bebeaththe wooden strip and use epoxy between wood and hull?
