Hunter Vision 32 mast bolts on deck
Apr 16, 2016
19
T-Craft TS18 Moraine
We recently had the mast stepped after being shipped via truck. The boatyard installed the mast but I see one bolt did not go into the threads below the deck ring. The one thread below the deck ring is slightly off center on the last bolt so they did not tighten the bolt. It is just inserted about 1/2 inch until it hits the off center threads. I have two questions on this problem. 1.) Does the mast ring need to be rotated so that all the threads will line up correctly with the bolts? 2.) If I remove all the bolts to try to align the ring around the mast do I need to have it hooked up to a crane to hold it in place? I am not sure the mast will stand straight when the bolts are removed and at +400 pounds I don't want it shifting on me and not be able to align it.
Rick D
Jun 14, 2008
7,207
Yes, it does sound like a slightly out of round condition of the ring. While likely OK, I understand wanting to have it right. One thought might be to slack off the other bolts to see if you can get this last one to seat. However, you have every right to be cautious. I think if you wanted/needed to rotate the collar, you would have to have the mast supported. My 2 cents...
Apr 16, 2016
19
@ Rick D Thanks for your reply. The owners manual says to use a star pattern when tightening the bolts. I'm wondering if not following the directions could have warped the ring. This was not a problem prior to the move and reinstall of the mast.
Rick D
Jun 14, 2008
7,207
Unfortunately, that does sound like a logical supposition.
Nov 6, 2017
78
Catalina 30 5611 Stratford, Ct
I would speak to the boatyard that stepped the mast to find out why they neglected to install the bolt properly. This is like getting your tires on your car replaced only to have the tech leave some lugs loose. Neither is acceptable.
