For what it's worth:
I have a Jabsco 29090 head, vintage 1996. It works O.K. Sometimes it squeals a bit and we put some vaseline on the pump shaft and it's OK for a while. Sometimes it pumps great, other times not so great.
(I ordered a new pump assembly as a spare, as it's $16 more than a rebuild kit, and lot quicker to deploy. Plus, it's an improved version.)
Anyway, I noticed the bowl rocking, and upon investigation found that the rear two bolts were hanger bolts that had pulled out of the wood-cored fiberglass mounting surface. The fronts were through-bolted. They were also undersized at 1/4". I replaced all four with new, 5/16" bolts, fender washers, and nylock nuts. It's very solidly secured now. I also rubbed some Super Lube on the pump shaft.
Now that it's secured, the pump works great! It pumps surely and solidly, and with no noise at all. It's truly a remarkable improvement. I have no idea why.
