Air Conditioning on a Hunter 326
Dec 7, 2017
10
Hunter 326 Holiday Marina; Lake Lanier
I apologize in that I am reposting this post from the "Ask a Hunter Owner" forum. I got no responses on that forum and would really appreciate some help.
I recently purchased a 2003 Hunter 326 and I want to add air conditioning to it.
I plan to locate the A/C under the starboard settee (as Hunter indicates in the manual).
The problem I have that while it is a large space, the slope of the hull limits the width versus height of the unit.
I would like to know what brand/models of air conditioners do other Hunter 326 owners have installed along with any comments or hints about positioning the A/C.
I've already surveyed a good bit about opinions of different brands. I need the specifics for a Hunter 326 due to the above mentioned space limitations.
Thanks,
Vernon
Dec 7, 2017
10
Do you find 12K enough? Where are you located? I'm in Georgia and was thinking 16K.
Gunni
Mar 16, 2010
5,937
Contrary opinion: 1/2 dozen or so low-draw boat fans and a 12k BTU A/C unit. You will want the fans anyway when away from the shore-power. Fans were what we used before marine A/C came along.
Oct 29, 2005
2,366
I'm located in Singapore. Weather probably like Florida but minus hurricane/typhoon.
For us, 12kbtu just about ok in day heat but pretty cold at night. Your mileage may differs.
Johann
Jun 3, 2004
586
Leopard 39 Pensacola
I have an H336 with a 12k mermaid located on the FL panhandle. It works well at night, but on a hot sunny day it will only maintain a temp delta of 12-15 deg from outside. There are a lot of losses in the long ducting runs. I plan on eventually adding a 5-6k unit in the aft berth area.
