Topping Lift Rigging
Apr 30, 2017
13
Hi guys,
Wondering how you all rig up the topping lift for the spinnaker pole.
Runs from the bridle up to the block up on the mast and then back down - doesn't look like I have a cleat or anything on the mast to secure it. Do you all run it aft?
Chris
Chris.. What type of boat? DO you have a picture of lower ten feet of the mast to the deck? Are any of your halyards rigged to be operated in the cockpit? Picture of the lines in the cockpit... Help me to help you.
Well sure jsg as he posted the question in the Catalina22 forum. I was just being cautious, not assuming he put the question in the correct forum.
Maybe it is just me. I read somewhere that if you want a good answer you have to ask a good question.
I would think if your going to have a spinnaker pole topping lift it only makes sense to have it controlled from the cockpit.
The question is "Wondering how you all rig up the topping lift for the spinnaker pole." With out the info about the equipment on the boat answering the question is a bit of guess work. While I know you can answer it and I can approximate a SWAG, not sure the OP has the necessary tools to implement the suggestions.
Apr 30, 2017
13
Just looked at the owners manual, they show the pole lift running aft. I think I can just attach a block at the base of the mast to run it back.
Yes that can work. Some folks get fancy and run the line through a rope clutch. Some folks use a fairlead and a cam cleat. And a few of us old guys install a cleat.
Your boat your choice. All are good options.
@Slartibartfass those are great images of your Capri 22. Good looking boat. Hope they can help @pointbreak805 as to how a boat can be rigged. You have fairleads that guide your lines back to the cockpit. Nice.
Jul 31, 2010
37
Catalina Capri 22 39 Seneca, SC
Hey @pointbreak805,
Wow, forgot there was a manual, thanks for the reminder. My setup is by the book, almost the same as @Slartibartfass though not as pretty. He's commandeered the stock downhaul/foreguy routing to serve some other purpose - probably a bow mounted harpoon gun or some other cool add-on.
Slartibartfass
Capri 22 Mod
Dec 13, 2015
499
Catalina Capri 22 1139 Mamaroneck, NY
Hey @pointbreak805,
Funny... the foreguy/downhaul is for the whisker/spinnaker pole and the yellow line is for the adjustable bowsprit that I can install at the front and adjusts the height/tension on the additional furler for the asym/drifter sail that I can install on there (both on furling units)....
A torpedo launcher to blast these annoying jet skies out of the water would be nice....
