Cockpit Floor Grate
Dec 28, 2015
1,945
I started my floor grates and got to roughing out the rear grate which starts at the pedestal and goes aft.
I'll update with pictures as I make progress.
I started by making templates using luan strips hot glued together. This is a countertop manuf. technique. This allows for making something with no square corners and unequal features like a fiberglass boat.
dLj
Mar 23, 2017
5,191
Also looking forward to your pictures as this is I something I am looking at doing down the road - after much more critical projects get done...
dj
Dec 28, 2015
1,945
Sorry for the teaser. The pictures I took are to big. I'll need to load them into my editor and make them smallee
Likes: justsomeguy
Dec 28, 2015
1,945
20180707_190337.jpg 20180707_190238.jpg 20180707_190303.jpg 20180707_190517.jpg 20180707_190506.jpg 20180707_190303.jpg 20180707_190238.jpg
Two sections. Rear goes from the front the pedestal guard back. Templates are luan strips put together with hot glue.
Mahogany using epoxy and loose tenon (Domino) construction. Rear section isn't finished. I wanted to test fit prior. The slats are about 1/2 inch off of the floor. I'll dado in channels on the bottom of the frame to facilitate water drainage. The one picture is of the bottom. I used a router (not my most professional moment as you can see) to remove material to accommodate the pedestal foot. I had a bunch of epoxy left over so I coated the bottom for direct contact rot resistance. I'll sand it all down flat. Finish with me a penetrating stain called Ready Seal. I use it on my Meranti deck and it works well. I have a semi professional shop that I have built all of my cabinets in my house with ( beaded inset faceframe) out of maple, oak and mahogany. All of my stock is either rough or thick that allows milling which I enjoy.
Nice. I learned that technique working for a stair company in Jupiter, Fl. You might know how to spile curved and irregular shapes too. If not, it is a technique that is worth learning. Google spiling or I'll be happy to tell you about it. An old boatbuilder's technique.
-Will (Dragonfly)
Dec 28, 2015
1,945
Never heard of her! Lol. I'll take a look. I manufactured my own countertops out of Paperstone and learned this technique while prepping.
Nice Mike. That is what you need on a regular basis.
Dec 28, 2015
1,945
Very nice. I have a good eye for design but I don't have a good hand for stuff like wood burning.
Dec 28, 2015
1,945
A couple months into our and the finish is holding up amazingly. Looks brand new. I ended up screwing a couple layers of flat webbing to the bottom on the corners to eliminate wobbling. Works great, allows water to flow underneath and is quieter.
