Well not "smokin hot" in the good sense...Ok, so here’s the story. We go out a couple weeks ago and while motoring I start seeing dark smoke coming out and the temp gauge is climbing. Well, we took it down to idle and let it run a while (it cooled) and when we came back in, we only used the motor for the last couple minutes to dock.
Now I’ve been reading all the engine stories for the 3 years we’ve owned this boat (2007 Catalina 309, 3YM20 with about 750 hrs). so I knew to expect a mixing elbow problem. I bragged to my wife – I know exactly what’s the problem. Proceeded to take everything apart over the next couple days and get the mixing elbow apart. Sure enough there’s lots of junk in there.
Did the following:
Took the boat out last weekend, same issue. At cruise rpms, things are ok, but if I push the engine, pretty quickly temps start rising and dark smoke starts coming out. Confirmed there’s plenty of water coming out the exhaust.
(See pics below of old mixing elbow and of engine with new one installed)
A couple more symptoms to note:
1. This started suddenly. I try to push the engine to near full rpm for a bit of our transit out the channel every time we go out. I don’t just baby the engine.
2. This is not accompanied by any loss of power/rpms. The engine is running well and the boat is moving along. I don’t trust the tach…but it’s saying I’m going like 3800rpms.
My next steps – check to make sure no obstruction in the air filter? Not likely but could be something simple like that. Also, need to get a portable tach to tell for sure the rpms.
Other thoughts - next things to start looking at? Any insight would be appreciated,
Dave in Tampa
Did the following:
- replaced mixing elbow
- exhaust elbow
- exhaust tubing to muffler
- hard-wall tubing from heat exchanger to vacuum breaker and back to mixing elbow
- rodded out heat exchanger
- replaced impeller
- replaced thermostat
- replaced input line to raw water pump which had a kink or bit of a collapse in hose
Dave in Tampa
