Hello all....
So in my scrambles before my few weeks away on the boat a new situation has arose. Beneteau has a fiberglass stern tube leading into the boat that has calking on the outside (underwater). On the inside, apparently when they put this tube in place they "poured" a slurry around it to seal and bed the tube... all good so far. However after speaking with many 423 owners it appears that the slurry in some cases has voids (bad pour) underneath where the stern tube comes through the hull so that if the calk on the outside fails, there is the potential for water to fill the voids entering the boat.... and like water is it will eventually find its way through..... In the spring while cleaning my bottom I did notice the calking was in need of eventual attention and I figured I would deal with it next year. I did not know the the situation at that time. Fast forward... so this season I have been getting water in the area.... could not trace it until the other day and did the research to figure this out. I will be getting short hauled next week and am looking to put a sealant on the stern tube.... At this point I don't want to use 5200 although eventually I may once I think the repair through. In the mean time I am looking for a durable fast curing sealant, that once it sits for a while can do the final curing under water.... I know 5200 is capable of this. I just want to be able to remove it in the fall when I have plenty of time to do a permanent fix on the situation.
Thanks!
Thanks!
