I have 2 questions
Hunter 26
1. how does the tack of the sail attach to the gooseneck ? I'm missing whatever connects it.
see attached picture. I assume it attaches to the small (squarish) hole on the top of the gooseneck, because the larger lower (round) hole is where the rams head hook should be..... for now, I'm just tying it to the smaller upper hole with some line, but know there should be some type of shackle etc to make this connection.. any pictures you have would be appreciated...
2. should the battens stick out the back of the main sail ? mine does by about an inch or so...
this makes the strapping that holds the battens in a little short as when you wrap it around the end of the batten only about a 1/4 to 1/2 inch of the Velcro actually engages... I'm thinking of cutting the battens a little shorter so more of the Velcro will stick together.... thoughts ???
Hunter 26
