Old and outdated is not all bad. I have a 1973 Perkins 4107. It is a beast. It is also like a Timex watch.Westerbekes are old and outdated.
is a factor to consider.cheaper availability of parts.
There's a good enough reason all by itself to go through it. It's a relationship between cost and use. If you're on a mooring and rarely motor, then spending 20k for a new one probably doesn't make sense, but if you're going to motor across Superior even once a year, you want absolute reliable. I had an International 6ltr version of an F250 that had leaky head gaskets. (they don't call them 6-leakers for nothing) The rebuild was worth more than the truck, at over 300k on the odometer, but I need the truck to haul the boat. Cost/benefit favoured a newer truck. Your math is different, but the same.in charter the first 6-7 yrs of her life.
Ha. Upgraded the shift lever from the Johnson bar to the more current side arm that Edson offers through CD. Found really quickly that the arm travel is reversed. Who knew. Not everybody has the capability to make a crossover jig....even if it’s jus shift levers and exhaust.
That's baloney. Westerbeke still sells and supports Westerbeke and Universal marine diesel propulsion engines, as well as generators of all kinds. They use the same Kubota and Mitsubishi base engines as Beta. Yanmar make their own, but are also based on their much larger tractor engine market products.Westerbekes are old and outdated.
Thank you for the kind words about my boat too, which is easily in the absolute top tier maintenance, presentation and operational category of the vessels around here, and that includes the much loved, noisy, stinky, old Westerbeke that it came with.Westerbekes are old and outdated
Thanks much,Now you know Mark, we are a diverse opinionated and avid DIY group with time, experience and some money that give freely of our information. On any problem we may agree or disagree. What is always a constant is the boat is your boat. Only you know how you want to use it and in what waters you feel comfortable sailing.
If you are planning to sail waters that have fickle winds and will put you at risk without a reliable motor then the idea of a "New" motor is appealing. Some here have had the opportunity to replace their motor. Non so far have accomplished the task without some bruised knuckles or gnashing of teeth and a few colorful words shared.
If I have learned one thing from this great group of sailors it is that when asking a question I will get information to improve the decision making I make on my boat.
