Hi all,
I was on the boat going over the list of repairs needed and had picked up a GFCI outlet for the aft head. The outlet had served us for 6 years and for some reason tripped last fall and wouldn't reset. I bought a Marunco identical to the old one so I thought it was going to be an easy swap.
First I decided to check for voltage and there was none. Then I pulled out the outlet and checked the wires for voltage, none. Next was the outlet in the aft cabin on the same side as the head, no voltage. So the next logical was to my wife's side of the cabin and the outlet worked, its a GFCI. So I tapped the reset thinking it could reset the current to the other two outlets, nothing doing. I pulled it out and both wires had current to and from the outlet.
Still thinking it was only one circuit I began the search for more outlets. Sure enough on each side of the headboard for the bed and behind the books on the shelf were two more outlets, one to a side. On my wife's side there was a GFCI that was tripped so I did a reset. It now had power and the one on my side of the headboard now had power. OK, now push all the books back into place and move to the outlet near the head that I had tried earlier. It now had power. I'm thinking great, now they all worked except the one in the head.
I checked the reset and it didn't work, but now the wires leading in to the back were hot. So I'm thinking bad GFCI just need to swap it out like I planned an hour or so ago. Three wires, hot neutral and ground, just like the old one. Put it all back together and the little green LED in the corner of the outlet is on. However the outlet didn't work nor would it reset. Dang, scratch my butt and call me lucky. I went through the whole process in my mind and still can't figure out what I'm missing.
Worked before that way, now doesn't. I tried scratching other body parts but didn't come up with anything. Any thoughts, I got a week before we go back aboard.
