Mine are just like yours. They were in the mast when we bought the boat, so I don't know how they got in. I'm pretty sure I could pull them out, but I'd need pliers to do it.
Sooooo....if that is the case, does anyone know a source for smaller round sail stops? The smaller Davis Stops #2351 are 3/8" FLAT. Would that work, or does it have to be a round stop?maybe your sail track is non standard and you need to jump down a size.
Really? Pliers? That just made our eyebrows go up. Interesting. So not easily taken out-able. hmmmm....Mine are just like yours. They were in the mast when we bought the boat, so I don't know how they got in. I'm pretty sure I could pull them out, but I'd need pliers to do it.
AHA. It is becoming much clearer. All this discussion has been very helpful....we now think it is probably by design for the round 1/2" stopper to NOT easily slip out through the mast track opening, but supposed to be installed from the base of the mast prior to stepping. This makes a lot of sense. It would also make a lot of sense for some stops to be flat, maybe like @rpludwig 's. I can just see the P.O. going to West Marine or ordering from CD and having the same head scratching problem I am having, and then ultimately deciding to go with the smaller 3/8" flat design because it DOES fit in the mast track opening AFTER the mast is already up.Siren....I'll stop by the boat tmrro and take a pic and measure what we have, couple/several sail stops there (flat, me thinks, that came w/boat) from PO...hang tight....but keep your pliers handy! You're gonna need 'em for other things anyway!
That's funny you say that.....I noticed the boom vang hardware attached to the bottom of the mast tonight and thought the same thing. You still get a beer, just because you joined the conversation.Ummmm .....Now that I think about it .... there is a cleat mounted in the sail track about a foot up from the bottom of the mast. If your mast is like ours, it's a pretty sure bet the stops were not installed from the bottom.
Do I still get a beer anyway??
Oh, reallllly?? Interesting. So give it a little push, and it will pop right in....but how do I get it out? Pliers? I'm flattered you chimed into this discussion. Thank you very much for your input!!!Push!
Siren, sail stop is flat 3/8", mast slot is 1/2"...no pliers needed...Siren....I'll stop by the boat tmrro and take a pic and measure what we have, couple/several sail stops there (flat, me thinks, that came w/boat) from PO...hang tight....but keep your pliers handy! You're gonna need 'em for other things anyway!
Pull.That's funny you say that.....I noticed the boom vang hardware attached to the bottom of the mast tonight and thought the same thing. You still get a beer, just because you joined the conversation.
Oh, reallllly?? Interesting. So give it a little push, and it will pop right in....but how do I get it out? Pliers? I'm flattered you chimed into this discussion. Thank you very much for your input!!!![]()
@Hardhead - YES!!! I was!!! It works perfectly!! I feel like such a goober because I didn't figure it out the first time. It does just take a little push, and it goes right in. Don't be scared to really push. The 1/2" Davis stops work beautifully.Were you ever able to get the 1/2" Davis stops to fit into the mast? I'm looking for sail stops as well and was about to buy the same 1/2" Davis stops myself.
