Good day all. I own a 1988 Newport 30 MKIII. I am trying to diagnose a problem with my Raymarine ST60 wind instrument. Long story short it works intermittently. I've tested the controller head on a friend's boat and it appears to work. I've tested the transducer per Raymarine's website and voltages appear within tolerance. Transducer wiring at the controller head has been checked and new spade connectors installed. So I am left wanting to examine the connections between the wires coming down the mast and running inside the boat. Thus my search for the elusive junction box.
The vessel has a deck stepped mast. There is no external conduit where wires are routed through the deck. Photos attached show the top of the compression post with a cast metal bracket attached to a molded fiberglass channel inside which, according to the original owner's manual, wires run to to the mast. There is no other obvious access panel. The bracket is about an inch in height, 2" across port/starboard and 3-1/4" fore/aft. It seems to me the junction box should be inside there.
Today I attempted to remove the bracket. I loosened lower and cap shrouds to ease the downward load of the mast and removed the screws. I could only get the bracket to budge by tapping it with a hammer firmly. Working slowing I got it to move about 1/4" before getting cold feet and backtracked. I became concerned about breaking the bracket or getting it out and not being able to get it back in. I saw no indication of an opening behind it but then I didn't move it out too far.
Does anyone know about the Newport 30 specifically or seen this kind of arrangement? I don't know what the junction box looks like or it's size but it doesn't look like there's much room behind that bracket if any.
Thanks for reading. Thoughts and expertise appreciated.
Len
Windborne
Newport 30 MKIII
Len
Windborne
Newport 30 MKIII
