I have a 1981 Hunter 27, with the Renault RC8D diesel.
I recently had an overheating situation, and determined that I had no raw water going through the cooling system. I ruled out a blockage of the intake, as I have water flowing to the water pump. When running for a short time, I removed the outflow hose from the pump, and saw that the pump was not discharging water. I removed the housing from the pump to inspect the impeller. I have attached a picture of the impeller in the housing. Here are my questions:
1. The impeller looks like it is in pretty good shape. Do they fail and still look this good?
2. In the picture, the water inlet is at the bottom right, and the outlet at the top right. To me it looks like the impeller should rotate in a counter-clockwise direction. However, the belt rotates it in a clockwise direction. Are the fins going the wrong way? what direction should the impeller rotate?
3. The scoring in the housing looks concerning. Is this anything to worry about?
4. There is no gasket or O-ring in between the housing and the cover. (it has never leaked). Is that correct?
Thanks for any info!
