Tough week for Cleveland sailors
Jan 13, 2009
394
J Boat 92 78 Sandusky
Two incidents on Lake Erie this week, 1 sailboat sinking, 1 death in separate incident. On Wednesday, a longtime Dragon sailor and champion died when he was struck in the head during an accidental gybe returning from the race course off Edgewater Yacht Club. http://www.nadragons.org/news He died from severe head trauma. The second incident was on Friday where a new boat owner lost power coming in to the Edgewater cut and the boat drifted in to the breakwall. http://fox8.com/2018/06/02/sailboat-sinks-after-boaters-are-rescued-near-edgewater/
Yikes
11,386
Yikes
That's all terrible news. Getting hit in the head with the boom is a sobering thought. As wind strength squares, a really breezy day can turn the boom into a weapon. We raced in 24 knots (gusting 32) yesterday and took two relatively new racers along as ballast technicians. Several times during gybes I had to remind them to be careful, and with the very shifty puffs watch out for accidentals.
JRacer
Aug 9, 2011
1,408
Wow. Bad news for sure. Boom is a scary thing when loaded up. RIP sailor.
Jan 13, 2009
394
Anybody have an idea what kind of boat that sank? Went down like a rock after that hole opened up.
Gunni
Mar 16, 2010
5,937
They generally do. Better question: what kind of ground tackle he had.
Sep 23, 2009
1,480
Not a critasim, just wondering why CG did not attempt to tow boat off rocks with captain still aboard and crew safely off.
Gunni
Mar 16, 2010
5,937
USCG has privatized towing to for-profits. I doubt those Coasties even knew how to rig a tow.
Likes: jon hansen
Jan 13, 2009
394
Problem getting too close to that breakwall with that kind of wave action. Breakwall recently rehabbed to make it higher. Most likely some large stones close in to breakwater. The wave reflection off the wall makes it a dicey proposition. CG around here will tow you off if you are in a perilous situation.
mm2347
Oct 21, 2008
243
oday 222 niagara
What a terrible thing to lose a boat. This sinking emphasizes that a sailboat should always have their sails or a sail uncovered and ready to lift if a mechanical problem arises. This unfortunate accident can be a terrible experience that all can learn from. At least we have one more thing to try.
Apr 5, 2018
95
Catalina Capri 25 Jackson
x2 on that. Tragic indeed for a new boat owner. Just something you have to anticipate, if your motor fails...you have a back up motor made of canvas. Happened to me last year, returning to the marina after a gusty race the outboard wouldnt start, by the time i gave up on it we were getting close to the rocks on shore so we said screw it, raised the sails and got away. My buddy was trying to hail us on the radio to tow us out because he figured our motor wouldnt start. Eventually we just sailed into the dock, luckily i had the slip at the end for the weekend, which made it way easier.
Gunni
Mar 16, 2010
5,937
I was coming to the marina a couple of years ago and there was a boat sideways near the breakwater conducting a Peking Firedrill. This is where crew are frantically running about the deck with their hair on fire while the skipper gestures wildly. We slowed to see if assistance was necessary and noticed that the sails were scattered about the deck and an effort was underway to get the halyards attached and sails up. Got the skips attention and asked if he was OK (he was not), said his engine had died going out and could we give him a tow. The answer was no, the quarters were too close to maneuver a tow but I did not want to say that to a panicked crew. "Toss your anchor", I said. His face lit up with the concept. He ran forward, pulled the headsail aside and released his anchor. We were in 7 feet of water and luckily he had a good anchor at the ready, it bit right away and he pulled it to his bow cleat. The boat swung to the anchor and about 90% of the drama ended.
They were still in the middle of a busy thorofare so we backed down and stood off their windward bow. The crew busied themselves with picking up the sails and I got on Ch16 to Securite the breakdown. The skipper came to the bow and we discussed the situation. He was safe for now but he needed a tow. I told I could not help him but that the marina fuel dock crew could. He hailed the fuel dock and when they responded we pulled off and went in . 10 minutes later or so he was being pushed to the fuel dock by the quarter and was home safe.
In a lee-shore FUBAR situation evaluate your options carefully. Your ground tackle may just be your best option to avoid disaster. Get yourself stopped up and buy some time to sort out what your options are. Maybe you sail off, maybe you get the motor started, maybe you get a tow. But you need a good anchor, properly configured and at the ready. Consider it one of your most important safety items. Carry two.
Likes: dziedzicmj
MitchM
Jan 20, 2005
1,031
very wise advice from gunni as usual on the anchors... that should be mandatory learning material in the us power squadron intro abc courses..
mm2347
Oct 21, 2008
243
oday 222 niagara
Not only can an anchor stop your boat it can be used to get an angle to the wind so you can raise your sail. A couple of years ago while practicing reefing my sails I realized I needed to be facing the wind to get the sail up or down. It dawned on me that it would be useless to try to raise a sail if the boat was at a wrong angle to the wind if I lost my motor. My solution that I have tried (in open water) is to use the anchor to pull the bow to the wind and then lift the sail or sails. ( It helps to get the boat turning while there is way on but can I react fast enough?) I have arranged my equipment so I can have the anchor out of the boat and tied off in seconds and then the boat swings head to wind. The pressure now off the sails they can be raised. I haven't been able to make the boat drag my anchor (it has always set) but the drag would probably swing the boat enough to get the bow into the wind. Would like to hear others on this.
Likes: BrianRobin
May 28, 2015
280
Catalina 385 Atlantic Highlands, NJ
Gunni ... as USCG family I can assure you those boys and girls can do anything they need to do whether asked or not ... best damn kids on the planet
Likes: FDL S2
DArcy
Feb 11, 2017
1,788
Islander Freeport 36 Ottawa
2 years ago I was putting away one of the club power boats I had just been using for setting marks for a regatta when someone started yelling about a boat in trouble. Two of us jumped in and ran out of the harbour to see if we could help. We found the boat in distress and rushed over but they set sail and were in control by the time we got there.
It was the C&C 115 I race on Tuesday evenings. Of course I gave the skipper a hard time about it but he was prepared and took care of the situation.
